Part Number: DP83822I
hello,
The customer would like to know what is different between 10 base-T and 10 base-Te.
Could you share information we can understand the difference?
Toshihiro Watanabe
hello,
Toshihiro Watanabe
The two interfaces are exactly the same except that BASE-Te has a lower signal amplitude to save on power.
https://www.iol.unh.edu/sites/default/files/testsuites/ethernet/CL14_MAU/MAU_Test_Suite_v5.4.pdf
Is there any small package PHY supported 10 Base-T? or DP83822 is enough for this requirement?
Toshihiro Watanabe
