Part Number: TPS65987D
Other Parts Discussed in Thread: TPS65988
Can you operate 2x TPS65987D on the same I2C master bus going to a MCU? In other words, both TPS65987D have Master I2C outputs connected to the same MCU slave I2C input?
Does the TPS65987D support multi-master? If it doesn't, is there any issue with configuration on a testboard? We are trying to get around using a TPS65988 dual port device on a test board only configuration as we can keep the fw the same on the TPS65987D.
