Part Number: DP83825I
Fig 16 of the DP83825I datasheet shows recommended Rhi and Rlo resistors for the strapping pins. But it also shows a 9K ohm internal pulldown. It's clear why Rhi would be needed to pullup, but is Rlo really needed for pulldown?
Tables 8 and 9 list a DEFAULT value for each strapping. I assume that is the value if no external pullup or pulldown is attached. This would imply Rlo is not needed.
The eval board shows a place to put the optional pullups, but not external pulldowns (see attached ti_phy_pullups.jpg).
Can you tell me when the external Rlo would be needed for a pulldown?
