Part Number: DP83867IS
I have a question regarding the thee-supply power sequencing. Please let me know if I am understanding the DS correctly.
According to page 110 of the DP83867IS Datasheet...
- When using the three-supply setup...
- You need to ramp 2.5V and 1.8V supplies at the same time, with 1.8V settling within 0~25ms of 2.5V settling. - YES?
- Or, you ramp 1.8V after 2.5V, as long as 1.8V still settles within 25ms of 2.5V ramp start. - YES?
- If the 2.5V is only powering the DP83867IS, then you can ramp 1.8V any time before ramping 2.5V...why?
Is it because if 1.8V ramps before 2.5V the 2.5V line will see the 1.8V, but if 2.5 only supplies the DP83867IS, it shouldn't be an issue?
What about the power-down sequence? Usually 1.8V is ramped down before 2.5V, but is that still true if 2.5V powers just the DP83867IS?
Thank you for your support.
