Part Number: TS3DV642
Other Parts Discussed in Thread: SN65LVDS22
Hello experts,
Hello experts,
no, SCL/SDA is only for low speed signal and not differential
Hi Ryo-san,
You can only use the +/-ve pins for LVDS (reference pin functions table in the datasheet). You'll need at least 2 of these devices to mux 6 LVDS pairs. A simpler solution would probably be using 3 SN65LVDS22 repeaters, but it looks like this device is more expensive.
I.K.
Hello Brian-san,
Thank you for your reply.
I thought we can use SCL/SDA because these have similar Ron with D0A~D3A.
Could you tell me what parameter is different?
Thanks and best regards,
Ryo Akashi
Hello I.K.-san,
Thank you for you reply.
Could you tell me what is the difference between +/- ve pin and other pin?
From Figure 20. Logic Diagram and Ron, I'm not sure the difference.
Also, thank you for your suggestion.
Ryo Akashi
Hi Ryo-san,
SCL, SDA, HPD, and CEC are not differential inputs and have different architectures. For example, SCL/SDA are DDC/I2C pins. You can't connect LVDS to I2C/DDC.
I.K.
Hi Ryo-san,
Sorry, it looks like I was mistaken about these pins. You are correct that there is no difference between +/- ve pins and the other pins. It looks like SCL, SDA, HPD, and CEC are not actually specific to I2C/DDC or other HDMI signals, but are only labeled differently to match up with HDMI applications. They can still be used mux LVDS signals. Please see here for more details: https://e2e.ti.com/support/switches-multiplexers/f/388/p/436201/1707024#1707024
Sorry for any confusion.
I.K.
Hello I.K.-san,
OK, I understand we can use SCL/SDA HPD/CEC for LVDS signal.
Thank you for your comment.
Ryo Akashi
