Part Number: TPS65983B
Hi Team,
Can TPS65983B support 20V/3A setting?
from GUI, the 20V/4.25A current cannot be modified. However, there is some product from the market showed it can support 20V/3A.
BR,
SHH
Hi Team,
BR,
SHH
Hi SHH,
Using the same register, check the field "Port Power Capability" and edit it to reflect your system. You could try 60W.
Please note this requires "Static Charging" to be selected at the project level. You are also responsible for checking any changes you make against your system and verifying resulting operation.
Scott
