TUSB7320: PWRON#1 is changed to High abnormally by plugging in/out USB port
Part Number: TUSB7320
Dear TI
As I know with EEPROM connected on I2C port of TUSB7320, TUSB7320's configuration can be programmed.
And at my design I did not use EEPROM and I2C port is pulled down to GND directly(actually 0 ohm series resister are located between SCL/SDA pin and GND).
So I expected PWRON#1 will not be changed during the operation.
But if USB memory stick is plugged in and out several times suddenly PWRON#1 is changed to High so finally VBUS is cut and USB memory stick is not recognized.
Could you please let me know why PWRON#1's status is changed and how to avoid it?
Thanks a lot for your support in advance.
YK Lee
