Part Number: LMH0384
My customer is asking SDO output schematic layout.
Current design is to utilize top layer PCB -> thru DC cutting cap -> thru LVDS receiver.
what if differential signal line are well controlled as 100ohms impedance matching with same pattern length,
Customer can utilize internal layer in addition to top layer? if possible, Would you please kindly share max Length (distance, how long mm or cm) from SDO terminal without video signal has not been issued?
Regarding SDI terminal, Customer well know SMPTE spec. But I am not aware OUT specification detail.
Thanks for your support.
Hironori Yoshimura
