Part Number: SN75LVCP601
Greetings,
The
IBIS-AMI model set of files seems to be missing the Tx/Rx s4p models, is there a way to generate these for us?
Shalmon
Greetings,
The
Shalmon
pls use this model with link below
Hi Brian, thanks for the quick reply.
I might be missing this but doesn't look like the Tx/Rx Analog Model exist in this file set, the http://www.ti.com/lit/an/sprabw3/sprabw3.pdf manual calls for draco_40nm_*_ txdac_.s4p corner files for both the Tx and Rx models.
Shalmon
Hi Shalmon,
It seems like the s4p files are defined as "pdf's" in your computer.
I have attached a user guide which describes the use of the lvcp601 rx and tx termination files to achieve the different EQ and DE settings in the device model.
Lee
