Part Number: LMH1228
Hi team,
In order to write the register, I believe it needs SPI length of 25bits because the register command syntax is 25bits in total (RAW + address + contents + mask=1bit+8bit+8bit+8bit). But, the datasheet describes SPI timing for only 17bit length. So, there is no location for "register mask". How should I locate the register mask? Could you show me the SPI timing for SPI length of 25bits to confirm the SPI timing of comlete register command syntax?
Saito
