Part Number: TLK105
Other Parts Discussed in Thread: DP83822IF
I use the ethernet PHY TLK105 in many designs. But now the PHY is NRND.
Replaced By DP83822I – The device has the SAME FUNCTIONALITY and PINOUT as the compared device but is NOT an exact equivalent.
DP83822IF – The device has the SAME FUNCTIONALITY and PINOUT as the compared device but is NOT an exact equivalent. The DP83822IF device is a pin-compatible upgrade of the TLK105 with fiber support.
TI does not recommend using this part in a new design. This product continues to be in production to support existing customers.
Can I replace the TLK105 1:1 with the DP83822I without hardware changes or do I need a redesign?
