Part Number: SN65HVD62
Hi team,
If SYNCOUT is not used, is it recommended to leave it open?
Itoh
Hi team,
Itoh
Hello Itoh-san,
Yes, it is OK to leave this pin open if it is not needed in an application. The recommended pull-up resistance is only needed when the pin is used to signal to some other device since the output stage uses an open-drain structure and an external pull-up is expected to drive the "high" logic level.
Max
