Part Number: TPS65987D
I am trying access the SPI Less Host Programming Over I2C Application Note for the TPS65987D (slva972a.pdf) but the link to it appears to be broken. Can it please be fixed?
Chamira Perera.
Chamira Perera.
Hello Chamira,
We removed this app note from our website. We can share this document on a case by case basis, but in general, we believed that the support to help every customer bring up this feature was too great. Apologies for the inconvenience. If you have not started this implementation, I would recommend using the external SPI flash solution
Hi Adam,
Thank you for your prompt reply. Actually we're prototyping a solution which has the TPS65987D as a PD controller and a microcontroller interfaced to it on I2C1. We didn't put down a flash thinking that we would be able to configure the TPS65987D completely via the I2C interface. Therefore, if you can please share the document I would appreciate it. Please let me know how I should proceed to get access to the document.
I was looking through other forum postings in e2e.ti.com and noticed that the external micro may need about 64KB to store the full program required for the TPS65987D. I'm hoping to use the Application Customization Tool to generate the required program.
Kind regards,
Chamira Perera.
Hi Chamira,
Please message me on the forums or have your local TI FAE reach out to me and I will share it with you there
Hi Adam,
Thank you for your reply. I've sent you a message via the forums.
Kind regards,
Chamira Perera.
