Part Number: TPS65987DJEVM
Other Parts Discussed in Thread: TPS65987D
Where can I download the TIVA firmware source code on this evaluation board?
TIVA source code is not open. The EC code snippet for the particular application has been provided in the respective application note. You can refer the same for code implementation in your EC.
Tnx
Prajith
Prajith,
Can you please send me the link to the application note.
Arif
Hi Arif,
AN http://www.ti.com/lit/an/slvae21a/slvae21a.pdf has code snippet for SPI Flash Firmware Update Over I2C (Rev. A).
Tnx
Prajith
Hello Prajith,
Trying to write the TIVA code to prgram the TPS65987D is an enormous task. I bought the FTDI cable to use with the TPS65987D configuration tool but it doesn't work. That leaves me with a very expensive proposition of buy the Aardvark programmer ~$400.00 !
I would like to buy a cheap TIVA board for $15.00 and use it with the TPS65987D configuration tool to configure the TPS65987D device. I think the TIVA source code should be made available to TI customers.
Thanks.
Hi Arif,
Apologies for the delay.
I'm checking with the internal team on how much the code is ready to release to the web.
Appreciate your patience, will get back to you soon.
Thanks and regards
Prajith
