Part Number: TPS65987D
Table 21 in the TPS65987D datasheet suggests using a Winbond W25Q80JVNIQ flash. First, it seems to me that the flash part number is incorrect - it should be W25Q80JVSNIQ. Second, this flash has Quad SPI enabled as a factory default (since the part number ends with IQ), but as far as I can tell the TPS65987D does not support Quad SPI. Could you please clarify whether it is actually possible to use this flash with TPS65987D and, if yes, then how?
Thank you!
