Part Number: TPS65987DDJ
If I just want to check bin file that do I need connect any adapter board to my system or just run TPS6598x Configuration Tool ?
Are you checking the bin file on your system? You can run a checksum comparing the system bin file and the one you produced using the configuration tool.
You need the configuration tool to generate the bin file initially. There is nothing internal to the configuration tool to compare two binary files to one another. You will need a separate program
