Part Number: DP83867CR
Encountered a problem, 1000M mode is working normally, but 100M mode is not normal, check the register of 83867 and found no problem, can you give some suggestions?
B&R
Hardy
B&R
Hardy
Hi Hardy,
How are you configuring the phy in 100M mode?Is this link partner in 100M or 1000M or in auto-neg mode?
Vikram
Hi Vikram,
The phy and the partner is auto-neg mode. And the partner is in 100M. The phy is auto configure 100M after auto_neg.
B&R,
Hardy
Hi Hardy,
Let me know if you can try out following :
1. Writting 0x001F=8000 or toggling resetn pin once you see the problem. Does phy links up now in 100M?
2. Forcing phy in 100M and try the link-up (to isolate whether the problem is with auto-neg mechanism with partner or 100M mode itself).
Vikram
