Part Number: TPS65987DDJ
Hi Team,
Customer is designing type C monitor
Would you please review schematic and provide comment?
Here is the schematic link.
txn.box.com/.../6od3shpk2qrhzbzfenmxafpwo7foahre
BR,
SHH
Hi Team,
BR,
SHH
I've assigned this issue to the relevant expert who will get back to you shortly
Hi SHH,
see my input on the attached check list.
Hi Kevin,
Thanks for feedback.
Would you please review the layout and provide comments?
txn.box.com/.../t72lfa2lqpqot1d6ofbocb4cvpiu9nva
BR,
SHH
Hi SHH,
I can't open the PCB file, could you please help check if the file is ok ?
Kevin
Hi Kevin,
Would you please use the viewer to open the layout?
http://s3.mentor.com/pads-free-viewer/PADSViewerVX.2.5.zip
BR,
SHH
Hi SHH,
the key point looks good, below is my additional suggestions:
1. looks customer doesn't us PP_HV2 and VBUS2, it should tie to GND.
2.add copper under FET thermal pad for thermal dissipation, please refer to section 11.6 on datasheet.
Kevin
Hi SHH,
Since I have not received your reply for several days, I will turn off this item. If you have further question, you can reply it again.
Kevin
If this answers your question, Please click "This resolved my issue" button.
