Part Number: DS90UH949-Q1
Hi
We are doing TDR testing. May i know the acceptable tolerance for the test result ?
Hi
Hi PYTsai,
The tolerances listed for the part are available in Electrical Characteristics table of the Datasheet. The IBIS model for the device is available here:
If more data is required than what is supplied in the datasheet and IBIS model, please let me know.
Sincerely,
Bryan Kahler
Hi Bryan,
Customer would like to use USB type C connector for FPD LINK. They would like to know the TDR tolerance requirement at the connector side.
Is it correct the differential impedance of the connector in the range 80 ~ 100 ohm is OK ?
Hi PYTsai,
To minimize any common mode noise generation the TX PCB interconnect, the interconnecting media, the RX PCB interconnect, and the termination should all match (within 10%) in characteristic impedance (differential mode).
An Application Report on LVDS Design-In guidelines may be found here:
http://www.ti.com/lit/an/snla008a/snla008a.pdf
If more information is required for the channel spec, please send me an e-mail as it requires an NDA.
Sincerely,
Bryan Kahler
