DS250DF810: survey retimer solution.
Part Number: DS250DF810
Hi Team,
can i use the TI_DS250DF810 retimer for the following function block? if there is any reference design or suggestion.
look forward to your reply.
  • Hi Tommy,
    I had checked IN112525 and it seems this is a quad channel CDR or retimer. However, we were not able to get detailed info. DS250DF810 is a 8-channels 25G CDR and as long as VCO frequency and electrical interface is compatible you should be able to use DS250 with this part. Please refer to the DS250DF810 data sheet and check if VCO range and electrical interface is compatible with IN112525 device.
    Regards,, Nasser
