Part Number: DS90UB954-Q1
How can I reset the camera's power supply when using 954?
There is 953 on the other side and it is powered from a coax.
Hello Ronen,
Are you using TI EVMs? Or a custom system?
Casey
It is custom. Is there any register to config so the power will be shut down?
Hello Ronen,
PoC is an external circuit to the FPD-Link devices. If you would like to shut down PoC then you need to disable the power supply which is feeding the PoC network on the 954 side. Since this is a custom board I'm not sure how that is controlled in your system.
Casey
