Part Number: DP83822IF
Hi all,
I started my once project using PHY DP83822IF with Master mode configured in RX_DV strap pin, but when measuring the clock out in pin RX_D3 is got approximately 40Khz rather than 50Mhz.
i have already verified all power and ground pin including the pins XI and XO that have 25Mhz and followed the Power Supply Recommendations
would like know what can happening for causing this fail?
Kind regards,
William Leandro
