Part Number: DP83848I
Hi team,
My customer need to pass surge 2kV common mode between RJ connector and Earth on DP83848I board, they found that transformer will be very hot after surge test, when adding pull up ressitor 4.7k resistor betwwen 3.3V and TDC_P will lower the temperature. My customer have two questions about this ressitor,
1.Can we add pull up resistor? What is the influence if they add pull up ressitor?
2.They found some data loss when resistor is 4.7k, what is the value we recommend to pass surge test?
Thanks.
BR,
Charles Lin
