TI engineer Hello!
My device used DP83867ERGZT chip, using 100 BASE-TX full duplex mode. My equipment can only connect 20 meters below the network cable, more than 20 meters of network cable can not connect to the Ethernet switch.
I need help and advice.
can you provide the signal quality inspection method or process support for the equipment to connect the long wire.
Thank you very much
