Part Number: SN65DP159
i will use the IC to source DVI videoa and i will not connect DDC line to communicate the source side and the sink side. Should i connect SDA_SNK/SCL_SNK or SDA_SRC/SCL_SRC from the source SoC device to the DP159? I am asking this because there is a note in the datasheet as you can see below.
Murat.
