Part Number: TPS65988
Other Parts Discussed in Thread: TPS65987D
Hello Team,
I had a question in regards to the TPS65988 programming.
1. External SPI/EEPROM memory needed for configuration? then how to program the memory and let us know the availability of the tools for both HUB and PD controller.
2. Is it possible to configure the upstream and downstream port without the external memory?
3. Does the Existing Firmware Handle charging the upstream port and simultaneous data transfer from Upstream to the downstream port
4. Does the Existing Firmware Handle External Power to VBUS Power switching without Resetting the device ?
