DP83867E: Impact of power sequencing
Part Number: DP83867E
Hi team,
The datasheet states the following regarding power sequencing:
"When powering down the DP83867, the 1.8-V supply should be brought down before the 2.5-V supply"
- Is it also acceptable to bring both supplies down concurrently?
- What is the impact of that?
Thanks in advance for the support.
Obinna.
  • Hi Obinna
    Per our datasheet we recommend the 1.8V supply be brought down before the 2.5V supply.
    There is a similar question on e2e already with your same inquiry. The sequence in this situation still had a voltage difference at power down. Would the same occur for your design?
    Cecilia
