Part Number: TPS65987D
Other Parts Discussed in Thread: TPS55288
Team,
my customer is looking for I2C compatible DCDC solutions that go with TPS65987D.
I know TPS55288 Buck-Boost. Do we also have a Buck we can recommend?
Nominal Vin = 28VDC
Thanks!
As far as I know, the TPS55288 is the best device for this type of application. I will tag a team member responsible for the TPS55288 and see if they have any other suggestions.
In the mean time, would you be able to elaborate on the type of system this will be designed into?
Dear Sir,
You can let the TPS55288 works in the buck mode. It can achieve very high efficiency. If you need a buck converter, then please open a new thread asking about the buck converter. The person in the buck product line will answer your question.
