Part Number: USB-2-MDIO
Other Parts Discussed in Thread: DP83869HM
I want to know the speed of the MDIO interface of the software USB-2-MDIO,could you tell me ?
Hi Cong,
I am checking the dependency (if usb-2-mdio version or msp version matters for this?) Which msp430 are you using?
Vikram
Hi Cong,
MSP firmware decides the MDIO frequency. Please share the link of firmware you are using.
Vikram
Hi Cong,
We dont have the information about the MDC frequency. Best way for you will be to measure it.
Vikram
Hello Cong,
which device are you using, which EVM and which MSP430 SW revision?
There are different versions available and the clock speed can be different depending on the device flavor.
A quick solution is, to just measure the MCLK on the device.
Hope this helps! BR Ralf
we are using DP83869HM part for Media Converter Mode,according DP83869HM specification,the interface of MDC maximum clock rate is 25-MHz.
I want to know the software USB-2-MDIO can help me realize it(25MHZ)? if not ,please help me .
Hi Cong,
I dont know the exact frequency of MDC with the firmware you are using but it most likely will be lower MHz or KHz. We may not have firmware for 25MHz.
Vikram
Hi Cong,
I am still checking around but still have not found any mapping between firmware vs mdio frequency. I have asked from one more team and will get back to you in 2 days.
Vikram
Hi Cong,
I tried to find mapping but I could not find firmware vs mdc frequency mapping for you. Looks like testing the board with firmware is the only solution for you to find out.
Vikram
