Part Number: TUSB9261
Hi, can not update firmware from 1.05 to 1.06
System is Win10, Burner and firmware downloaded from https://www.ti.com/product/TUSB9261
But button to Programm is inactive https://imgur.com/3Zxdg2l
Is it possible to disable the SPI flash momentarily through a enable pin on your system and then connect the TUSB9261 to the PC? Allowing the TUSB9261 boot device to connect (pre-firmware load) should allow you to re-program the connected SPI flash. Please be sure to re-enable the SPI flash before re-writing and be sure the the SPI flash is not write or read protected.
