Part Number: DP83826I
Dear team,
I'm trying to promote DP83826I as a pin to pin solution against KSZ8081RNB for our customer. I understand that these 2 solution are not BOM to BOM for strap resistor value difference.
I've done checking according to SNLA338, the only problem left is that PIN19 of KSZ8081 is floating on our customer's current design. Based on datasheet of 8081, "Pull-down (default) = PHY Address 0 is set as a broadcast PHY address".
Based on my understanding, PHY Broadcast Address is not supported for DP83826I. Does it mean that we only have chance for replacement if PHY Broadcast Address is disabled by software for 8081?
Thanks a lot!
Charles
