Other Parts Discussed in Thread: BQ78PL114, BQWIZARD
Which software and connector should use for bq78pl114.
bqwizard is recommended but it does not work I am using usb interface adapter I'm waiting for your help and answer in this regard
What is the error that is occurring?
Have you followed the EVM users guide?
Sincerely,
Wyatt Keller
I checked but this does not provide a solution.
Which version of window should I use?
For system requirements I would check this document: https://www.ti.com/lit/ug/sluu336c/sluu336c.pdf?ts=1595536445027&ref_url=https%253A%252F%252Fwww.google.com%252F
Some of the older gauges may require 32 bit and an older OS
Sincerely,
Wyatt Keller
Can you provide screenshots of the errors you are encountering?
Sincerely,
Wyatt Keller
Wyatt Keller said:Can you provide screenshots of the errors you are encountering?
I have assigned this to someone more familiar with bqWizard that can help answer this for you.
Sincerely,
Wyatt Keller
I heard back from my colleague:
it requires TI USB-TO-GPIO interface adapter with compatible firmware for bqWizard™ version 2.5 or newer/ – MCC iPort/USB™ for bqWizard™ 2.5.7 or newer version . And it only works with 32-bit Windows.
Sincerely,
Wyatt Keller
You will need to use the TI USB-TO-GPIO to communicate with the board with bqWizard.
Sincerely,
Wyatt Keller
I see you started a new thread for this new issue. I am closing this thread for now and we will provide our feedback in the new thread.
Andy
Yes it will proceed in the new case.
This is the new thread you opened, it appears to be the same issue: https://e2e.ti.com/support/tools/ccs/f/81/t/926807?tisearch=e2e-sitesearch&keymatch=%2520user%253A455532
Sincerely,
Wyatt Keller
