Part Number: PCA9534
Hi expert,
Customer found that PCA9534PWR had issues, that SDA signal showed random low.
How to do further check?
Hi expert,
Shenhua,
How repeatable is the issue?
How was the customer able to confirm the PCA9534 was the cause? (did they remove all I2C devices on the bus except ours? Did they do an ammeter check?)
What does the Vcc power up ramp rate look like?
-Bobby
Bobby
I am the hardware engineer of CIG, and I raised this PCA9534 issue.
The issue is repeatable,Signal of SDA could be found low almost every time when the board power on if the failed PCA9534 is on board.
We found this failed PCA9534 by Cross-validation. Signal of SDA keeps low when we remove all other I2C devices on the bus, but it will return to normal if we remove PCA9534. We checked these signals by Oscilloscope.
Below pictures are the Vcc Power up waveform and power down waveform. There is no abnormal conditions showed on the Vcc power up ramp rate.
Bobby
BOBBY said:ramp rate
