DS90UB953-Q1: Maximum power consumption
Part Number: DS90UB953-Q1
Hi team,
Does the condition in datasheet 6.5 maximize the power consumption of 953? Are there any other conditions that increase power consumption more than datasheet 6.5 "power consumption" value? Which clock mode is used for the test?
Also, for 954, could you check if the condition of datasheet 6.5 give a maximum power consumption?
Saito
  • Hello Saito,
    The maximum power number listed in the datasheet is the maximum worst case condition across voltage and temp range specified for device. The clock mode is synchronous. The same goes for 954 datsheet
    Casey
