Part Number: TPS65987D
Can the LDO_1V8 output be used to power an external 500uA load? Can you advise what the current limit (<<20mA) is for the LDO_1V8 to use externally and if this is recommended.
Hi David,
I don't see a maximum amount of current that LDO_1V8 can supply, so I would go off of the 20mA window. Having a 500uA load should not be an issue
