TPS65987DDJ: Where can I download the configuration tool for TPS65987DDJ (v6.2.8)?
Part Number: TPS65987DDJ
Other Parts Discussed in Thread: TPS65987D
Hi everyone
I use TPS65987DDJ on my new project. But configuration tool (v6.1.1) doesn't support this IC. I read about the tool v6.2.8 with support TPS65987DDJ. Where can I download this version of the tool?
  • You must request access to the collateral associated with the TPS65987DDJ. There is a request access link on the main product page for the TPS65987DDJ.
    However, I must first ask what your intended end equipment is. If you are designing a Thunderbolt system, then the TPS65987DDJ is the correct device. However, if you are not designing a Thunderbolt system, then you must use the TPS65987D. These devices are identical from a hardware point of view. The only difference is their internal firmware. The TPS65987DDJ firmware is designed for Thunderbolt systems, while the TPS65987D is intended for all other applications
