Part Number: TPS65987DDJ
Does the TPS65987DDJ simultaneously support 2 I2C masters, like the TPS65987DDH does?
Is there a way to enable both at the same time if we're not using TBT controller for any of the I2C Ports?
Hi David,
Yes the TPS65987DDJ also supports 2 I2C masters. You won't be able to enable both at the same time though but you can configure the multiple slave addresses in the I2C Master Configuration 0x64 register.
Thank you,
Hari
