Part Number: DS280DF810
Other Parts Discussed in Thread: DS250DF230
Hi Dears,
I am planning to use DS250DF230 as a re-timer in my new design which has CFP2 and QSF28 modules.
For compensation insertion loss of the 28Gbps signals path and connectors I need to use some sort of signal conditioning product.
After searching many products , I found DS250DF230 . but as I understood from the datasheet the register tables and addresses are not available.
1- Can you grant access for the DS250DF230 Programmer's Guide(SNLU182) ?
2- what kind of default setting was stored in the registers!? Does the chip work normally without extra modification in settings?
I’m very appreciative and thankful if you can help me to access the register tables.
Sincerely yours.
Masoud Babaei
