TPS65987D: Powering External Memory with LDO_3V3
Part Number: TPS65987D
Can LDO_3V3 be used to supply external flash memory when the internal 3V3 rail is also being used to supply the TPS65987D itself?
Michael
  • Hi Michael,
    Yes you may power the Flash memory using LDO_3V3. You may also refer to the TPS65987D EVM User's Guide which will also shows an example schematic where  the EEPROM has the VCC pin connected to the LDO_3V3.
    Thank you,
    Hari
