DP83TC811S-Q1: how to make Hybrid work
Part Number: DP83TC811S-Q1
hi team,
whether the PHY chip work in normal mode, register is configured master mode, and tx_ctrl is valid. The TXD+-(PMA) will convert tx_data?
And when is a Transmit Block or a Receive Block to Hybrid?  only working in normal mode, and config slave?
Thanks!
    I am not sure I got your query correctly. But you need not do anything to make hybrid work. When phy is in normal mode (either master or slave), data transmission will work fine without requirement of any special configuration of hybrid.
    Vikram
