Part Number: DP83TD510E
we want to use the RMII Low Power Mode of the Phy DP83TD510E (datasheet chapter 7.3.6).
- Which strap option muss be used in Table 7-7 MAC Mode Strap Tabel for RMII Low Power Mode?
- How to activate this Low Power Mode because there is no Strap option for 5-MHz in the Table 7-7?
- The special registers, which are mentioned in chapter 7.6, are not documented. Do we need them for using this RMII Low Power Mode?
Thank you for you support!
Hermann
