Part Number: DP83822I
Hi Team
My customer is using DP83822I and concerning the heat dissipation.
They are thinking improve it by pattern design.
For now, they had 5 vias(center and four corners) on exposed pad of DP83822I,
is there any suggestion to pattern design for better heat dissipation ?
Also, they are thinking downsizing the resistor around DP83822I to have more surface space, and use the
space as GND solid pattern, is there any other element (i.e. pin) contributes to heat dissipation besides exposed pad?
And does it work for heat dissipation if they place GND in surface layer by connecting via of exposed pad
through GND solid pattern of inner layer ?
Thanks.
