Part Number: TPS65987D
Other Parts Discussed in Thread: TPS65987, TPS65988,
Hello TI Team,
there was this thread, where it was found that the TI software tool could not program software protected areas in a flash (At least how I understand it).
With Brian helpfully provding a python script, they together with Aaron found the issue, and Brian noted that they should fix the software tool.
We are now looking into placing a smaller flash IC (MX25V5126FZUI) as well, but are now unsure if it will be programmable through the tool.
Could you please either
- Confirm that the functionality has been added to the TI Tool for TPS65987 and/or
- Confirm that the flash IC is compatible with the TPS IC.
In this thread, an older, obsolete part number (MX25L512E-ZUI-10G) was confirmed as working.
Thank you!
Kind regards,
Daniels
EDIT: Fixed broken links
