Part Number: TCA9800
Other Parts Discussed in Thread: TMP1075, , TCA9803
Hi team,
My customer is evaluating the TCA9800 with TMP1075 on their board. Please refer to the block diagram from the following link.
/cfs-file/__key/communityserver-discussions-components-files/138/I2C-Temp-Sensor-circuit.pdf
The customer found that there was about 500mV of voltage on the L signal in the signal between the I2C buffer(TCA9800) and the temperature sensor(TMP1075).
The d/s of the I2C buffer states that external pull-up resistor is not required on the B-side, but on the other hand, the d/s of the temp sensor states that external pull-up resistor is required.
The customer is currently connecting the pull-up resistor as shown in the block diagram, should they remove the pull-up resistor?
Yamaguchi
