Part Number: TUSB8041
Dear TI Team
I have the issue that the PWRCTL1,2,3,4 Pin is going Low every second when I have upstream a Jetson Nano and on the USB2 of the Jetson Nano a WIFI Module. I have only the issue when there is only one connection on the downstream side of the hub. I think there's a problem with the overcurent. But the Fault Pins of the switches are always TRUE.
I tried the same with your Evaluation Board and have seen the same problem.
When does the PWRCTL Pin switch? Can it be that the upstream host switch something?
I need your help urgently.
Kind regards
Matej Ravlija
