Part Number: TDP142
Hi Team,
TDP142 supports DP1.4 as stated in the datasheet but does it also support DP1.4a? Datarate is the same but some functionalities are different. Please confirm!
Thanks!
Roy
Roy
The only change with DP1.4a is the implementation of DSC 1.2a, which improves upon DSC 1.1 and 1.2 with better support for HDR in the compression algorithm and improves color support. The bandwidth does not change as you pointed out in your question, so the DP142 will still support DP1.4a.
David
