Part Number: PCA9548A
Hi Team
Good day !
My customer use the PCA9548A as the IIC switch , in their application , they found that , after the power on , the device work fine , It can work with the configuration , after they switch the channel and communicate with the load , the PCA9548A will reset itself and do not active , the only way to recover the problem is power off -on .
They want to test the load side signal , but if they use the Oscilloscope probe , the device will reset and stop communication. Multimeter is OK.
Do you have any suggestions about this query ?
BR,
Leon.liu
