Part Number: DP83822I
Hello team,
Do DP83822I IO pins accept 3.3V signal while VDDIO=2.5V?
I want to know if MDIO/MDC/RESET/INT/XI works with 3.3V input signal when VDDIO=2.5V.
Itoh
Hello team,
Itoh
Hi Itoh,
If VDDIO is set to 2.5V, the maximum voltage that the IO pin should accept would be 2.625V. Any voltage level higher than this could potentially damage the IC.
Gerome
Hi Gerome-san,
Thanks.
I'm just a little curious. How can I find that information from the datasheet?
Itoh
Hi Itoh,
This information is located in section 7.3 of the datasheet, Recommended Operating Conditions.
Sincerely,
Gerome
Hi Gerome-san,
I think it specifies the VDDIO supply voltage.
But I understand.
Itoh
