Part Number: TPS65987D
Is there a thermal sensor inside the TPS65987D, which value can be read out from I2C registers?
Boris.
Boris.
Hi Boris,
You should be able to use 0x78 Received Status Data Block (SDB) register which contains some temperature info of the device. You can refer to Section 5.5 of the Technical Reference Manual for more details on this register.
Thank you,
Hari
