Part Number: DP83826I
Hi.
We will be using DP83826I with a discrete magnetics (XFMRS P/N: XFATM9B). Datasheet is attached. In the following layout considerations from PULSE Transformers and another write up in Signal Integrity magazine, it was recommended to make the differential pair trace length from PHY to the magnetics' input at least 25mm (~1-inch) to reduce EMI. I haven't seen this layout recommendations in any of the TI's, Microchip's, or Marvell Semiconductor's application notes. Is this distance required for Ethernet PHYs? Do you have any recommendation for the total trace length should be from the magnetics to the Ethernet PHY for best performance and EMC?
https://www.signalintegrityjournal.com/articles/1808-ethernet-connectors-and-routing-above-ground-planes
Fazlul
Pepperl+Fuchs, Inc. (Minneapolis)
fkarim@us.pepperl-fuchs.com
